in NE , opened pool Monday, got everything cleaned up, did a Taylor salt test , came back 1400ppm. that makes sense since the last month my pool was open it was low on salt and I never got around to adding any.
based on calculations my pool is 20k gallons, put it in the calculator for pool math and it tells me every 40 lbs should add about 239PPM, but based on adding 3 bags yesterday and running for 24 hr straight and re testing , the 3 bags added 400ppm each ? As I tested at 2600 PPM today. I don't think my gallon portion Is off cause everything else usually matches... even the bags of salt recommended on the bag calculation doesn't come out.
needless to say im 6 bags in right now shooting for 3400 and if I overshoot by 200-400 so be it , if im under ill add another bag.
