AZ,
The filter is not there to scoop up algae. But the time the filter sees algae, it is too late, you have already lost the algae war..
Algae is a chemical issue and not a mechanical issue.
If you are buying a robot to clean up algae, I suggest that you just save your money..
If you are buying a robot to help clean all the junk that falls into your pool and sinks, then I think that a robot would rock..
I have three pools and three robots, so I am a big fan. Then main downside to a robot is the initial cost and the fact that they are (more or less) consumable. They tend to last 3 to 5 years.
Because you most likely have that Arizona dust storm "fallout", I would recommend the S200 "Style" Dolphin robot. You can fancier ones, with the bells and whistles, but they won't clean any better, and it will last just as long. Dolphin sells the same basic robot under many different names, the initial one was S200..
I suggest you contact Marina Pool and Spa for the best price, delivery and service. Margaret can help you decide which robot you want.
Margaret Mills
Marina Pool, Spa & Patio
7777 West Jewell Avenue
Lakewood, Colorado 80232
303-985-0077
[email protected]
You have to call or use e-mail to make it an instore sale. They get busy, so you will have to hang in there.
