I honestly don’t know what to say other than I’m at my wits end. I’ve maintained a followed trouble free pool and the advice and knowledge for over 6 years with a 24’ above ground pool with zero issues. The last 30 days or so have been heck. I am unable to get the green out of the pool using the SLAM method. I’ve gone to the extent of replacing 60% of the water with new filtered water. I’ve changed out the sand filter to a cartridge filter three days ago 1.5 hp pump. I did make the mistake around the Fourth of July adding some algicide to clear it up quickly it was always blue/green but again replaced the water about 60+% with new filtered water.
I added a new 1500sq+ft deck around the pool using pressure treated wood and I almost wonder if the saw dust treated with some form of copper didn’t cause the issue. Although I’ve tested via the strips 0 copper, 0 iron so have a acid test coming in the mail now to be able to test “total copper”.
Here are the latest pool stats these haven’t changed much except the ph keeps increasing and the free chlorine keeps decreasing but no combined chlorine usually if it does show up it’s like .5 for a brief period.
