I have what looks like plaster in the pool/spa water , seems worse in the spa. The pool and spa were acid washed before it was closed due to black algae in some spots of both the pool and the spa. Both also had white stuff coming out the plaster walls (plaster?) The acid wash got rid of the black algae stains and the plaster stuff but 5 months later when I re opened the pool (spa stayed open with pump and heater running, I did not take care of it during this time though) I noticed the spa had this brownish debris settled at the bottom, some of it stuck even which is why I drained the spa right now to scrape it off. My question is what is causing this stuff to come out the plaster walls? It was also found in the filter and pump basket, as well as heater
I have got the pool chemical levels right now at
FC:10 (I shocked it yesterday, letting the sun hit it right now to get it down to safe levels)
CC:0
TA:100
CA:350
Cya:0
The pool and spa are connected but the pool water was not allowed to mix with the spa water during the pool was closed
CC:0
TA:100
CA:350
Cya:0
