I’m new to pools, and this pool is new to me but about 30 years old. I’m hoping the collective knowledge here can help with a few questions. Thanks in advance for your help!
How difficult an install would a salt water generator be with this pump/filter configuration? Is it realistic to fit without significant replumbing?
How do I evaluate the condition of the pool surface? Note the chip and white spots. I assume the surface may be a few decades old at this point.
How can I mitigate the black grass/weed encroachment just above the tiles? I’m concerned there may be a leak in some of the pool plumbing to enable this kind of growth.
Should I be concerned that the pool water supply shut off valve is PVC plumbed above ground as pictured? Minimal sun exposure but it’s Phoenix so very hot ambient many months of the year.
TF-PRO SALT test kit results below, is there any hope to salvage the remaining water? I’ve added about a gallon of bleach and half gallon of muriatic acid to start. I assume the CYA may require a partial drain at least.
FC: 1ppm
CC: 0.5ppm
pH: 8.2
CH: 550ppm
TA: 280
CYA: >100
FC: 1ppm
CC: 0.5ppm
pH: 8.2
CH: 550ppm
TA: 280
CYA: >100
