We just opened our pool about a week ago and need help balancing. Previous owner used chlorine tabs, but we're switching to SWG. When we opened, the bottom of pool was green and slimy. We had it tested at a pool store and they had us add 20 lbs bicarbonate, 8 gal shock, 1 bottle algeaside, 10 lbs borate, and 2 bags salt and manually vacuum, then turn on SWG. We did all that, except we left the SWG off because the salt is obviously not high enough yet, and they tested again and said to add 12 gal shock, 1spot kill in skimmer and 1/2 qt clarifier. I asked about the CYA being too high (it was 100) and if we should we drain some water first. They said it was high and we could drain 1/3 to 1/2 of the water. It would have been nice if they told me that the first time before we dumped all the chemicals in . We drained probably about 1/3 and haven't added anything else. The water is clear now. We used our kit to test ourselves and here's what we got this morning:
FC 6
CC 0
pH about 7.8
TA 150
CYA 70 (or could be closer to 65ish)
Salt 800
CH 175
Pool is about 30-35K, vinyl liner. What do we need to do?
FC 6
CC 0
pH about 7.8
TA 150
Salt 800
CH 175
