- Aug 12, 2023
- 43
- Plaster
- Jandy Aquapure 1400
Hello,
We just finished our pool build and PB was taking care of the pool for the last 3 weeks as part of the contract. However, I want to give it a try of taking care of chemicals and managing the pool. Its a 16K gallon pebble tec pool with attached spa and spillover. SWG is not turned on yet as its a new build. PB was adding chlorine pucks to manage I guess. Here are my initial results with TF-Pro.
Free Chlorine: < 0.5
PH: > 8.2
TA: 50
Calcium hardness: 170
CYA: <30
I also went to Leslie's and below are their results. Looks fairly accurate w.r.t TF-Pro. He mentioned about low FC and high phosphates as a breed for algae growth. They also gave list of chemicals as part of solution, which I am adding below.
Free Chlorine: 0.28 -- 9oz of Leslie's power powder plus or 11oz of leslie's chlor brite or 56 fl oz of Sodium Hypochlorite
TC: 0.28
pH: 8.3 -- 52FL of Muriatic Acid or 4lbs 1oz of dry acid
TA: 46. -- 12lbs 2oz of Leslie's Alkalinity Up
CH: 159 -- 18lbs 4oz of Leslie's hardness plus
CYA: 12 -- 1Gal 116 fl oz of instant pool water conditioner into skimmer or 5lbs 1oz of leslie's conditioner
Iron: 0.1
Copper: 0.2
Phosphates: 717 -- 61 FL oz of Leslie's NoPHOS
Salt: 200 -- Add 400lbs of salt. PB will add it sometime next week and turn on SWG
I have few questions which are below.
1) Are Leslie's solution recommendations accurate? If not, what are the other options?
2) Do I need to run the pump in high speed before adding these chemicals?
3) Leslie's mentioned that with high phosphates and low chlorine with cause algae growth. Is that true?
4) What are my next steps in terms of adding chemicals etc.?
Probably I should have gone through few posts in the forum before posting this message. But I am almost in panic mode with these results. Please advice.
PH: > 8.2
TA: 50
CYA: <30
TC: 0.28
Iron: 0.1
Copper: 0.2
