- May 22, 2019
- 53
- Vinyl
- Hayward Aqua Rite (T-9)
Hello everyone,
At the end of last year we had an in ground pool installed with a salt water filter. Previously we had an above ground chlorine pool so I’m familiar with the basics. However with the salt water pool I’m getting conflicting information rom different sources so I am trying to clear it up.
Back story - since the pool was installed late last year we didn’t really use it. The pool company instead it, land scraper finished the job, and the pool company closed it. We jumped in once just to say we did. Now that it’s opened im just getting familiar with how it all works with the salt generator.
After the pool company opened the pool and added salt, the filter ran for a a day or so. According to the salt meter the salt level was a bit low, so I added salt according to directions. It was at about 2300. Next morning it was at 4700. After taking to the pool guy it turns out the control panel was set to the wrong cell type. I corrected it and now it’s reading 3700 - 3800.
So just to confirm I took a sample to Leslie’s. They read about 3600 so it’s basically accurate. However their chlorine readings don’t jive with my Taylor test kit
They read the free chlorine at 2.13 and total chlorine at 4.82. My test kit gives me about 4.5 free chlorine and 0 combined chlorine. They said it’s because their test is more accurate which I can believe to some extent but that is WAY off.
Second they’re saying I need to increase my calcium hardness. But information I read online (and also information from the pool installer) says a vinyl pool (which I have) doesn’t need to have calcium hardness monitored.
So I’m looking for more information here. Any idea why the chlorine readings are so different? Also do I need to monitor calcium hardness for a vinyl pool? They also said I don’t need to dilute the pool to bring salt down. It’s not that far out of range and slashing and rain will eventually dilute it.
Any help is appreciated. Thanks!
BTW - the water LOOKS great but has a slight salt taste.
