Thanks! I lifted the rail very slowly (using my thinnest tie-down straps in hopes that they would serve as the sacrificial weakest link) and only high enough to drive the new boards under the support with a rubber mallet. Considering this pool is just a big sack of water, the approach worked pretty much as anticipated.
Reactions: kimkats
Hey, that seems very familiar! :ROFLMAO:
  • Haha
Reactions: bjmsam
The last swim of this second season was enjoyed thoroughly (83°F air and water) before the winter cover went on today with only cooler temperatures in the forecast. Looking forward to next season with a new solar cover reel (details to follow)!
AL9nZEWeyWRv1fjqz40H3vo-RXRyosawoVKFfp8RBa-8M_nT3UUu14dRMiCUqDXa8vInuZBLsA27lTGnQr3v3_vYbikAFO-WY6Yg1M--mZjk25qqXoXPK4ZvMuqj2EdQsZYrEj9g9SmcKo3Zpi1J8KNrFQTIbg=w1538-h1153-no
AL9nZEUFi7hhmDK1AD2OYJO8wU9oTtUWQLijzv34GGXU9jKlAAGM22o_ev0zw1sUKlzmdQNdR-KR7XuzDKIBn9v7d7t_eqG2tVEBwPWi0WssBuxX7vqTWExcJ1baQdK8CsBtYpZhVI9o7CcPTNAJIP6t6WLHfw=w1538-h1153-no
Thanks! He did a terrific job, and it is super stout. Smooth cranking and no sagging!
Air temperatures are forecast to be in the mid-80°F range here by the end of this week, but my water temperature is only 59°F, so today I removed the cover, engaged the filter pump and solar heater, and started to SLAM!
AJFCJaVSbuSlkfZ7sthlbBFFAZ1u-7q908c3bbovl9Nn8_m5kTynW8wLWyzhxoDfWDbvKFAM_JTV9MqTVs2PK-HxNSoJfRUJ0c_8Le11UMQNjTgA2GgziLODIDmV5EoAhy8ttyO6lq732A8qnJMmDRoowPmCBw=w1401-h1051-s-no
AJFCJaX3xdUSZnefWdYY8o-qOTw94eXqvXM0-TuaZbR_MaW5L335lqEa6MZZCzFjr1DfgmgeGyy4NpbKpnxSG-os4v37Flo_EgKzu7MOHied6gGj3o5gZzZd9aU1WgiL6SMCwFJ1Z8yrDKhHclW5QwQVMsJ_BQ=w1228-h921-s-no
End of week update
First swim of season three: 12 May 2023 (vs. 14 May 2022 and 27 April 2021)
Air Temperature: 85°F
Water Temperature: 73°F
AJFCJaWGw3GWfbTggZqg4u_mreLQCWF0bjOIIrNBsuyh9mqwewq8YCydBtE7vWoUJqY3EMx4ybhhjjgsPzl4XydmfKcDyuqLY8BCwr2M0_VapKAYAbayfACLG_35CLPHcAnNkaOrhoQteNkZEj2OWoRMvnnZ-Q=w1228-h921-s-no
Thank you! We certainly are enjoying it.
As posted in another thread, we recently added an Inkbird IBS-M2 Wi-Fi Gateway with IBS-P02R-O Thermometer:
My pool is too far away from the house for the sensor to communicate reliably with the gateway, but as my Wi-Fi signal is strong (TP-Link CPE-210), I mounted the gateway in a waterproof enclosure mounted to the deck. It's convenient to monitor air and water temperature at the pool, and with an additional IBS-P02R-O sensor, water temperature at the pond, too!
AJFCJaUvx6HDtlRUf4izthmVd41luPf-UzmVJvOOS3_8iPv9-qShb2qzA2y417k6sp4TLqIKTrKwnzm8uakTd29l-gjR-BXPB9hiXdWbc-5NkK9n1JBO2PEsI9YOrHaiEmuVC-e7smkFP9BYtFL96I37L2BwLA=w1401-h1051-s-no
"IN" reflects air temperature and humidity measured in the box (which is warmer than ambient due to sunlight upon the box and electronics within the box, but about how it feels when sitting on the deck - I have since relocated it to the north stair stringer where it is shaded by treads and risers) while "OUT 2" reflects water temperature measured at 4-6 inches below the surface of the pool. It's interesting to see the temperature fluctuating daily while trending up weekly:
AJFCJaU0uDLWpdFSNg7nAYfisr_3YPSnvbYgBTQyCduX82rqKbnR_WQ2a5ddVJMChd7ebbq6tOJ6ioe8fcG9N6E5fsmVfjTXTeLpjytaEiq5BBAPQaPspPwyDPpExuZEYUiSAjdgVsBasV9CZCA8TVCcjXYG_w=w619-h990-s-no
Surface temperature is elevated before we start swimming and the water mixes:
AJFCJaViocesLocYQvzpILJY8Bxd6c14AbA5mjcnLhOquQ93lZGZdnDNGPhOrVwYX1AWGhWUoktWYTNa3IN1ntjWu2ajw9aQkTRG-AuZmK6Iiq3fu1dCJ70kLoI9C3EgkDCLoUAcwnXrvyCAhbQQbqZrkau3-Q=w619-h990-s-no
June wasn't a great pool month due to drifting smoke from the Canadian wildfires, but July is making up for it!
AIL4fc-HHYgZA2Z6hwac4mSEqa4R9h3tCkItGtmFx8buzQCYySdPEAtTqJbp52MJS8YawmLV_D_VspCDaT-hWHUWd9OwpsjAme5LdazVzNXnHhAXtuPKktpNscd_lL8EXuLZCAExEUOawOdSv95SUB_K_diz1w=w1200-h532-s-no
Nothing really to report other than replacing the failed Intex pressure gauge with a better one using fittings that orient it for easier viewing given how my filter is positioned.
AIL4fc8-nFQ8LBvWol8aCXuWdM4xPxSblVmiwQ2hCTn8PLTEqPkrr1Fd0FwNXRGEW95254-Uq7yo7o--ZgovDlCF9AdjCkqMYJYX5ITKhajlUk0KjQf3odd7EXTfqbmkjbQdDowkh65_eRgIA79CPyf6yn6bTw=w1254-h941-s-no
AIL4fc9BWM00Ry9Cnn0BOtVVs0hAE0motMXVypR8R4DnZKn3YjH2z3GUUbLS0iIRXCazNGw4_oAHz2hfXs4jC1wcC7GHR0x0dxwgMSyzn0qE08uRNh0_2zK0SCjM26s1qz6RLfXgJs1jefsrKF5s0yHh1NGrZw=w1254-h941-s-no
AIL4fc_IvAz13SBC357w0MFeUrgLflYmWWukI2lUBWqQ1yNlW7tEHPhm3LZQieZHMjBJnd2Zz8-I6QEtVjj-HgTGLsh8v3yl6-S9kN11NmSnIQx8Aunjx8cMRjjaPjvsM96guLfgUqYNRVb-mEsGiWljkiMf2A=w800-h1066-s-no
Lightning struck a tree in our pasture and fried (among many other things) the Intex pump's GFCI plug and controller board, but this helpful post and schematic restored service prompty!
I was able to get it running by bypassing the control circuit board and display board.
img_7824-copy-jpg.359040
AP1GczOr8pnmytIVlshZBsPTn-HmfHmrAq0JClT4IT81NuSPJ6usFlsIHNk76cVLlqE6b6kC2ATshF80tH59ZOrDZxT7n_m_h3_42epHZZvXLtpYWnMZy7jEbSf5RENDNN4DrCzN8LpDyA7fgwwJ2YF8BSR93w=w966-h727-s-no
AP1GczPv5n7Uvd0dU3pqIyS_4FIhgYeSch8nD2aDcNETY56ktpOB2xOgaYbhRpah5zkYFONzkxwU5nNy8ZwC5B4OQR16BIDuJCK0bdbLFlx_sHLiY7is25We1rZWqpJLgd9oblMPutc8msXVi5-RzYYukUEJSw=w547-h727-s-no
No functionality has been lost, as the pump was controlled by an external timer anyway. 😥
I might of missed it, but what thermometer do you use?
It's the IBS-P02R-O.
More info in the other thread:
Thanks for your testimonials, which helped inform my purchase of an Inkbird IBS-M2 Wi-Fi Gateway with IBS-P02R-O Thermometer. My pool is too far away from the house for the sensor to communicate reliably with the gateway, but as my Wi-Fi signal is strong (TP-Link CPE-210), I mounted the gateway in a waterproof enclosure mounted to the deck. It's convenient to monitor air and water temperature at the pool, and with an additional IBS-P02R-O sensor, water temperature at the pond, too!
Something flew off with the one in the pond, which was tethered!
Reactions: Mdragger88
Thank you! Added to my cart, now I just wait until $90 doesn't sound crazy for a thermometer I can look at on my phone, lol. Usually a couple vodka sodas make all purchases seem reasonable.
I have the ambient weather station (love it btw) and they sell a $30 submergeable sensor I would recommend over the floating one. It's cheaper and you can use pool patches to adhere it to the side wall of your pool so it stays out of the way. Only downside is the unit is not waterproof. I just used a ziplock bag and zip tied it inside.
You of course get all the charts.
