- May 30, 2012
- 1,995
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I was just standing here measuring CYA and the thought hit me. Does an easier manual method exist?
Rather than a sight tube with a dot, I was envisioning a wedge shaped vessel. A vertical back, flat sides, and a slanted front. There would be a black line down the middle of the back. You fill it with solution (heck, you could even have reagent and water lines on it, no need for a separate mixing vessel). Then you sight it from the front, the level where the black line is occluded (by the increasing distance viewed through the water as it gets lower into the wedge) indicates your CYA.
It seems to simple to not have been put into production. Maybe because it uses more reagent than the other method?
