- Jul 29, 2017
- 220
- Plaster
- Pentair Intellichlor IC-40
Here are a couple things that I need to have clarified.
The manual says that the cell turns off when the water temperature falls below 52d. The Further Reading article says that it turns off when the temperature is below 60d. Why the discrepancy?
The manual also says that the cell needs 25 gpm +/- 5. My current pump low setting is 28 gpm. If it works once will it always work, or should I just keep it over 30 to be safe?
