- May 9, 2023
- 12
- Vinyl
- Pentair Intellichlor IC-40
Hello, I have an Intellichlor IC40 that only works in boost mode. I have tried the following:
- unplug it and/or turn off the breaker
- replaced flow switch
- hold down more button (nothing happens)
- press less+more buttons to turn off boost
- waiting a few days
I have no automation - just the IC40 and the power unit. Consistently, I will notice that the led for good salt level and the flow less are solid green. But then I press either more or less and the output less scroll left to right and the cell light goes on and solid green. It will run this way for a while then go back to solid green salt led and flow.
I can’t get the output to do anything other than scroll left to right which I’m almost positive is boost mode. The only other thing I’ll add is that the 2/20% output led does not work at all.
Any suggestions before I go buy a new one.
