I took my ic20 out last October and put in a dummy. I put the working unit back in today and got a no flow error light, flashing salt lights, and the screen logic app reads 0PPM salt. I discovered that the flow meter switch broke and have to replace it…but I didn’t think the flow switch had anything to do with salinity readings.
Chem test shows salt at 3800ppm. Pool temp was 68f. Ic20 diagnostic mode read the temp correctly (both the 60 and 80% lights were on solid).
COULD the busted flow switch lead to bad salt readings? Or is the whole unit bad?
