Hey guys, if you take good care of your pool. Meaning the filter is optimal, the chemicals are balanced.... then should you see yellow build-up if you miss brushing for just one day? I know this probably isn't exact science, and most likely everybody is YMMV. If I miss brushing for just one day, I start to see yellow build-up, it's not obvious. But if I look for it, I can see some, and if I brush it away, you can see the yellow dirt move in the water. If I miss brushing consecutive days, then it gets more obvious. Is this normal, do you guys have to brush every day?
