Hello!
I have a 22k gallon in ground vinyl lined pool. We bought our house in 2021 and had never done pools before. Worked out fine the summer of 2022- added chlorine tabs and shock and didn’t think much about it. Then we let it go green in the winter and last summer was a whole mess. Discovered TFP sometime in July/August and have attempted to learn as much as possible since! Of course we let the pool go green because it basically already was, so I’m in the process of opening/slamming our swamp now. My question today is: I’ve added now two gallons of liquid chlorine and even just 30 minutes later I only have 0.5ppm FC and 0.5ppm CC. Is that typical? For the chlorine to just get zapped up that fast? And if so, why isn’t my CC higher?
test results from Taylor k2006c kit:
pH 7.0
FC 0.5
CC 0.5
CYA 15ish (slightly less than the 20 on the tube)
Another question: I’m using a leaf net to scoop up the junk on the bottom, but I have zero visibility so I’m kinda just guessing. Is there a better way to accomplish this? Should I vacuum to waste?
pH 7.0
FC 0.5
CC 0.5
