I am trying to do the TFP philosophy but can't get my water under control to start. The pool looks cloudy but pretty good otherwise. My phosphates are out of control (1710) so I added a phosphate remover and it's down to 1122 but still cloudy. My CYA is 100 and my FC is 5.93. What should be next? I'm getting different info from the pool store, so I'm not sure what to do. Thank you!
Hi Sheridc,
Welcome to TFP!
First of all, TFP is an easy way for pool owners to take care of their own pools.
The pool stores are in business to make money. They will use all sorts of jargon to sell you something expensive that really will not help you.
Also, TFP does not trust Pool Store Test Results. They are inaccurate and cannot be trusted.
Lots of info in the posts above and it can be overwhelming. But relax,
everyone is saying the same thing in their own words and trying to help you.
Lets keep it simple right now. Here are a few tips to get ready to fix your pool.
1. The cloudy water is
not due to phosphates or TDS. So don't worry about it and ignore anything to the contrary.
2.
You need a good test kit to test the water yourself and often. Please visit
Test Kits to get a test kit. At a
minimum, you will need the TF100 kit. If your pool is a saltwater pool, then get the TF100 Salt Test kit. All of the other kits listed contain the same stuff plus some 'luxury' items that are great to have, but not a minimum requirement.
3. Once you get your own test kit.
Follow the instructions supplied with it, record the results, then come back here and we can help you out.
4. Please fill out pool description in your SIGNATURE. It will save a lot of time in us helping you.
5.
Go ahead and download POOL MATH now. You will need it in order to help determine how much of some chemical you need to add or remove from your pool water, based upon your test results and the size of your pool.
In the meantime while waiting for your test kit to arrives.
Go ahead and get yourself a few gallons of Liquid Chlorine or Bleach without any scents or splashless additives.
Pour 1/2 gallon into the pool each day and run your pump at least 30 minutes after adding it.
We look forward to helping you out, but more importantly, we look forward to you enjoying a sparkling spotless pool for a fraction of the cost you've been spending up until now.
