- Sep 12, 2023
- 153
- Vinyl
- Pentair Intellichlor IC-40
When you say the bypass works… have you gotten the bypass valve to open/close based of HP demand? If so, did do that through the EasyTouch or through the HP?No update on the automation…still trying to figure that out…the bypass works fine. Attached is the wiring info..anyone on here have any advice. Heat pump has been enable on controller.
I know the HP can control 2x 3-way valves and I’m hoping I can utilize that built in feature to regulate bypass of the HP pending HP demand… fingers crossed.
