- Oct 18, 2022
- 8
- Plaster
- Hayward Aqua Rite (T-15)
Hi. We have the subject Heat Pump (HP) installed on our pool. The user manual is rather rudimentary, and was hoping someone could validate my understanding -
Heat mode - set temp at water temperature target low (when on in heat mode, HP will try to keep water at or above this temp)
Cool mode - set temp at water temperature target high (when on in cool mode, HP will try to keep water at or below this temp)
Auto - when on, will attempt to keep water between settings for low and high.
Example - Low (Heat) 86, High (Cool) 94 - auto will attempt to keep pool between 86 and 94.
I recognize this is not a “smart heater” and is operated by Omni in a remote switch fashion. Thereby, the HP has no idea what Omni wants, other than it said turn on. BUT, using the settings at HP control as described above, and duplicating settings at Omni, I can force the Auto mode control from Omni. Before 4.3.1, only way to switch between heat and cool was to manually change mode at HP. Was hoping 4.3.1 would resolve this manual change (first world problem here).
Any thoughts on this?
Note - Heat and Cool both worked fine at MSP 4.1.1. Upgraded to MSP 4.3.1 to get Auto functionality at Omni. Now HP won’t come on, even though Omni says it’s calling for heat or cool. I will delete HP configuration in Omni and re-configure to try and address that issue.
