- Jun 22, 2014
- 47,854
- Fiberglass
- CircuPool RJ-45 Plus
I think everyone has the same concern .... algae. We won't know that for sure until you get the proper test kit. If it had been something you added to the water previously that may have gummed-up the filter, it would be gummed-up all the time. But since you are able to clear some of the pressure with rinsing, there must be some organic material you are washing away. As soon as you crank-up the filter, it traps more. The TF-100 or Taylor K-2006 test kit results will help us confirm that. Adding the bleach for now simply helps to keep anything from getting worse until you kit arrives.
