Determine correct pipe diameter?
brew4eagle
48
Stafford, VA
I need to order a new multiport valve and I'm not sure if I have 1.5" or 2" connections to the pool lines. I've learned in the past with household plumbing that it isn't always as easy as it sounds (e.g., inside vs outside diameter, different connection types) and in fact it's often the opposite of what seems obvious.
Anyways, here's some pics of my MPV with a ruler. Seems like 2" connections to the pool, is that correct? Or is it 1.5"? TIA!
You have to measure the pipe and not the fitting.
See the chart below. Measure the outside diameter of pipe. Focus on the dimensions of either 1.9 or 2.375
It looks like yours is 1.5inch pipe.
Reactions: brew4eagle
