I seem to have an issue with my filter. Just finishing my slam and my filter seems to plugging up quickly when I add DE to it. I have a feeling this is normal but I would have to backwash daily if I keep adding DE.
without DE I can go several days almost a week without backwashing but if I add 1/2 cup of DE the next day My pressure is up past 15 PSI. clean pressure is normally 11.5 PSI. after backwash it doesn't always come down to 11.5 sometimes stays at 13. but the other day I guess I didn't have the pump basket cover on properly and I was getting air bubbles in the pump and return jet and that made the filter pressure go down by itself without backwashing. probably went from 14 PSI right down to 11 just from the bubbles.
I do think the guys that installed the filter added only filter gravel to the filter instead of sand. my guess is I should have gravel on the bottom and sand on the top or all sand. I still have a light brown sediment scattered in the bottom of my pool I am assuming is dead algae from opening and slamming. I have vacuumed once and it doesn't seem to come off. I guess I should brush then wait for it to settle then vacuum to hopefully remove more of the sediment.
anyone else having weird issues when adding DE to their sand filter. otherwise water is clear. I have a feeling my filter cannot filter out the light sediment so it is just pumping it around.
