Hi - I'm not a new pool owner but as always, i'm running into new problems. I am having an issue (actually started last season) where i seem to continue and lose chlorine. I have a Fiberglass pool (36X16) that has a SWG system. I feel i'm pretty on top of my chemistry readings and use the LaMotte system to daily check my FC, PH, and ALK. I monthly check my Calcium and CYA. I also check my phosphates every couple of weeks because I understand that is something that can eat away at chlorine. Yesterday, for example, I tested my FC and it was just over 3 and my CYA was 59 - this was taken in the AM. No one swam yesterday and we didn't receive any rain. The PH was 7.4 and ALK was 74 so I did add in some increaser as well as added some CYA to try and get it up to 70. This AM I checked and it was down to 2.5 FC where my PH was 7.5 and ALK was 104 and CYA was 69. I added some reducer. Last week I tested my phosphates and it showed around 200 so I added some Phosphate reducer. Below are some other facts/things and I'm just looking for thoughts:
- I just cleaned my filter (cartridge (CS200)) and it was seemingly dirty. I do this about every month, or sooner if it seems I get a bit of air in my pump basket
- I currently have my SWG up to 90% which seems outrageous. I used to be able to manage my FC with no more than 40% or so running the pump at a slower speed.
- I run the pump around 2200 rpm 24 hours a day.
- when it was not as warm (in the upper 80's/low 90's in Richmond, VA this week) it didn't have an issue with generating or maintaining the chlorine so the heat def. has a factor, but I still can't figure out why i would need to even consider anything close to 100% (esp. when it still is not keeping up).
- Total Chlorine is always within .10 or so, which I believe tells me it isn't really working that much?
- I did add a couple pounds of shock over the weekend which took it above 5 for FC but again, it has been dwindling ever since.
Any suggesting or things to consider - i'm all ears. I am wondering if with a clean filter I might see some improvement?
Thanks
Mike
Thanks
Mike
