- Nov 12, 2017
- 11,956
- Plaster
- Pentair Intellichlor IC-40
Easier, for sure, but I have a different MO. I want my pool as warm as possible as soon as possible. And I want my SWG to run during peek sunlight hours (so that it is replenishing FC as it gets used up). So that means 8:00am to 4:00pm. My solar doesn't always come on at eight, but often does. So I wouldn't want to set it for 10:00 and miss those two hours, even if it wasn't happening every day.Just seems easier to start the pump a little after the sun first hits the solar temperature sensor so they both start at the same time. No reason in my mind to start it any earlier anyway. This is what I do with my system. If you need extra run time, put that at the end of the cycle instead of the beginning.
So your MO would certainly work, but, at least for me and my pool, it wouldn't be ideal. Another factor, though not one of mine, is that some folks need their runtime to coincide with the cheapest electricity, so sometimes the hours best suited for the pool are not best suited for the bill.
