Evening folks, im starting to regret not draining the pool. I’ll keep it short as i possibly can.
27000g Semi in-ground pool, 425sq cartridge filter, 3HP variable speed pump runs 24/, 2” piping in/out.
Pool cover came off in a wind storm early winter, was too busy to care so I left it open all winter to swamp out figuring id drain and refill, due to record rain and wet soil i didnt want to chance it so here we are 45lbs of shock later…
Starting Numbers
0 CYA (closed at 90)
50 TA (closed at 120)
8.6++ PH (off the charts red purplish)
240 CH
Opened by netting as much of the gunk off the bottom as possible, vacuumed a bunch to waste, cleaned filter and repeat a few times then began. Added a gallon of muriatic acid. Added a few lbs of cal-hypo shock and realized real quick i had ammonia, took 15lbs 56% cal-hypo + 4g 10% liquid to start holding some* chlorine, went from dark green to extremely cloudy white, This was 3 days effort but due to work i was forced to leave it for a week.
Started back up 2 days ago for round 2, the entire time ive been vacuuming, cleaning filters and brushing non stop. 15lbs of shock added over a few hours to maintain 10-15ppm then went to bed, woke up to 5ppm FC and 3ppm CC. Added 6lbs to get it back up but throughout the day in sunlight I struggled too hard to maintain 10ppm and due to 0cya I didnt want to keep throwing money away so I added 4lbs of CYA to skimmer this afternoon. Soon as the pool was shaded at 6pm here I added enough (roughly 10lbs) to bring it up to 29ppm FC hoping to hit breakpoint and lower the CC…..and still had 3ppm CC. I Just checked (it’s been 5 hours) FC is 17ppm and CC is now FOUR PPM?! Water is still extremely cloudy white haze, and smells like chloramines.
Current numbers
(Ran out of CYA reagent, should be 15-20 now I hope)
8.2 PH (Was at 7.4-7.6 earlier today while FC was below 10ppm before i started the heavy round)
17ppm FC
4ppm CC
70 TA
240 CH
The increasing CC is worrying me, the water refuses to clear up in any way or show signs of clearing and the insatiable chlorine appetite after THAT much shock and liquid is unreal, were talking 50lbs of calhypo 56% and around 8g of 10% liquid.
Ideas? Opinions? Thank you.
Starting Numbers
240 CH
Current numbers
17ppm FC
4ppm CC
70 TA
240 CH
