Thank you all at TFP! Best Pool Site Ever.
I converted to TFP method years ago, after the pool store merry go round had me draining and refilling pool (after only 2 years) to lower CYA. All was great until my laziness got the best of me and I stopped testing and just threw chlorine in until it looked good. Last year and a half I have seriously neglected the pool.
Now, I am trying to get back on track and need your help again. I opened the auto pool cover (pool being covered all the time is probably only thing that saved me from swamp) and found a huge amount of yellowish growth on the pool wall shady side. After looking through TFP determined that it should be Yellow Mustard Algae. I have had this before in same spots but it has always gone away with a few days of balanced chemicals or just adding chlorine. This time there is also a ring around the pool at water level that is yellow and green. There is also loads of the stuff inside the skimmer spillway and at the bottom of the spa spillover. All shady areas. But, this time it is going no where so I started a SLAM.
Problems I have had for a long time:
PH always seems to want to stay high >8
TA always seems to want to stay high >150 (I have done the Acid and Aeration method to reduce but always goes up)
CYA biggest mystery to me. Since drain and refill I have never been able to get CYA to register. I have used the liquid gold nature stuff and the granules in sock in skimmer method but never seem to get results.
Starting SLAM measurements
FC 0
CYA 0
PH 8++
Raked, brushed, vacuumed the pool, cleaned cartridge filters, pump on 24/7.
Brought PH down to 7.6
Used Dichlor (Leslies Chlor Brite) 1lb bags to start chlorination and quickly raise CYA.
DAY 1 (evening)
3lb Dichlor (to raise CYA by 18 and FC by 20 supercharge)
PH 7.6
FC 19
CC 1
DAY 2
6:35am Water murky, Brush, no change in appearance of Algae.
FC 16
CC .5
7:30am Water murky, Brush, no change in appearance of Algae.
FC 15.5
CC 0
8:30am Water murky, Brush, no change in appearance of Algae.
FC 15
CC 0
9:45am Water murky, Brush, no change in appearance of Algae. Realized I have been doing FC test from memory and only adding 1 scoop 0870. all further tests with 2 scoop 0870.
FC 12.5
CC .5
CYA 0-20 (test water cloudy but dot visible all the way to top of tube).
11:15am Water improving, no change in appearance of Algae.
FC 10
CC .5
12:30 Water improving, no change in appearance of Algae Added 1lb Dichlor (now 64oz total should be CYA 24)
FC 8
CC .5
PH 7.8
1:30 Water improving, brush, no change in appearance of Algae Added 16oz Muriatic Acid to bring down PH added 32 oz 10% liquid C
FC 11
CC .5
4:00 Water crystal clear, Brush, no change in appearance of Algae. Added 32oz 10% liquid C
FC 12
CC .5
DAY 3
7am Water crystal clear, Brush, no change in appearance of Algae.
FC 11
CC <.5
CYA 20? (still fill to top of tube but much harder to see black dot then before.
I will retest PH as soon as FC is below 10 and adjust if necessary.
QUESTIONS
CYA seems to be going up. Should I add another 2lbs (32oz) Dichlor (one 1lb at a time) to raise CYA above 30?
Is it normal that I cannot see any change in the visible Algae yet?
Is it normal that brushing seems to have no effect on the Algae? The brush doesn't make any marks in the Algae and it doesn't seem like anything gets brushed down or into the water (no clouding or residue from the brushing).
Should I do a TA, CH or other tests?
In addition to the Algae I have a stain across the bench in the deep end. The infloor cleaning system shoots dirt up onto the bench and whoever designed neglected to put cleaners on the bench so it just sits there. I let it go for a long time and I think that it is dirt on the step that has dug into the plaster. Brushing has no effect anymore. See pictures. Is this also Algae or dirt? In either case, how would you suggest I tackle this issue as well?
THANK YOU IN ADVANCE!!
PICTURES OF ALGAE
SHADY SIDE WALL
CLOSE UP SHALLOW END STEP SHADY SIDE WALL
EXTREME CLOSE UP SHALLOW END
DEEP END SHADY SIDE WALL
DEEP END BENCH I ASSUME IS DIRT ATTACHED TO PLASTER BUT NOT SURE. IS THIS DIRT OR ALGAE? HOW DO I GET RID OF THIS?
FC 0
CYA 0
PH 8++
DAY 1 (evening)
PH 7.6
FC 19
CC 1
DAY 2
FC 16
CC .5
FC 15.5
CC 0
FC 15
CC 0
FC 12.5
CC .5
FC 10
CC .5
FC 8
CC .5
PH 7.8
FC 11
CC .5
FC 12
CC .5
DAY 3
FC 11
CC <.5
QUESTIONS
PICTURES OF ALGAE
SHADY SIDE WALL
