Thanks. I put it into service mode and no display on the pump. Probably my fault, because the original pump was a single speed pump and I didn’t change the wiring. How should I change it up?251
The first thing you need to do is identify your pump/filter relay. In theory it should be the one in the upper left. The problem is that if an idiot wired it, it could be any one of the relays. Look at the main board and verify which relay is plugged into the Filter/Pump connection.
It appears to me that your IntelliFlo may not be wired correctly.. Place the system into the Service mode and tell me if your pump's display is working or if it is blank because it has no AC power.
Your new Power Center should only get power from the load side of the Pump/Filter relay. This prevents the cell from getting any power if the pump is not being told to run.
You also need to wire the Power Center's RS-485 connector into the main boards RS-485 connector. DO NOT do this with power on as it will blow the RS-485 chips.
Yes, wires feeding the vs pump should just be moved to the line side of the pump relayI traced the wires back from the pump. They are wired on what looks like the load side of the relay (circled). Do I just move both over to the line side (arrows)? Looking for confirmation before I do it. Thanks. View attachment 477821
Thanks!Yes, wires feeding the vs pump should just be moved to the line side of the pump relay
Mine was (still is until I get controller fixed) and I had an electrician wire mine. That was back in 2017. I guess I missed that in the wiring instruction. Live and learn!Thanks everyone, that worked! I can go into the pump menu now in service mode. I can’t believe I didn’t realize it wasn’t wired correctly for this long. I guess when I installed it and everything seemed to work correctly, I thought all was good. So now for the chlorinator power center, I just attach the yellow and white wires to the load terminals where the pump was originally wired? Does it matter which wire (white or yellow) goes to which load terminal? Do a leave the black and purple wire as is with the wire nut? Thanks again for your help. This site is invaluable. View attachment 477836
