So I'm almost ready to close my pool. This will be my first go at this. I know that I drain water below return and skimmer. I know that I detach hoses and store filter/pump indoors.
I will be using a winter cover with a pillow under it. I know to remove the steps also. Do I need to remove the return/jet fittings from the pool? Do I remove the skimmer? Also all I read was to bring water to SLAM levels. Is that all that's needed chemical wise?
