Sorry in advance for the long post. I am a first year pool owner in Utah (Cold Snowy Winters). I have a pool/spa combo with shared equipment. I want to winterize my pool, but continue to use my spa in the winter and have been looking for advice on what to do. I came across this article online that provides info about how shared systems work:
Shared Pool & Spa Systems
The article says:
“If you live in a cold climate area where the pool will need to be closed and winterized then you will also need to close and winterize the spa if they share equipment. For some people that is no problem, for others, like myself, the cold weather is the besttime to use a hot tub, and closing mine for the winter would be out of the question.”
I have an automated shared system gunite pool with a main drain and in-floor returns. All of my pool equipment is an an insulated, heated shed with a generator backup for power outages. Wouldn’t it be possible to blow out the main drain, skimmers, and pool floor returns simultaneously while in pool mode using a cyclone blower attached to a modified pump lid, and then air lock the main drain, skimmers, and pool return lines by switching the system into spa mode? My understanding is that switching the system to spa mode closes valves on the pool return lines, main drain, and skimmers so that the system draws water only from the spa and returns water only to the spa. Is my understanding correct and would this work to airlock/winterize the pool plumbing?
If so, then I could just make sure that I leave the system in spa mode all winter long to maintain the airlock in the pool. Please let me know if you think this would work or if there is something I am missing.
Also wondering if you would try to plug the floor returns with a rubber plug after clearing them while continuing to blow air through the pool plumbing or if you think the air lock is sufficient. I’m a belt and suspenders kind of person, So if plugging them after blowing air through the system to clear them wouldn’t hurt anything, and could only provide additional protection, I’m likely to try to plug them.
Please let me know your thoughts. Thanks in advance!
The article says:
