Winter scheduling with Pentair Superflo VSP
rwmcmahon
11
Virginia
Hayward Turbo Cell (T-CELL-5)
I would like for a Winter schedule is to have just one low speed for the duration the filter is powered (either by schedule or freeze control). The end state goal is as follows....
warmer temps > 38 degrees: 9 hrs per day at 1900 rpm
colder temps <= 38 degrees: All hours of the 24 hr cycle at 1900 rpm
I would like to confirm the below settings to achieve the above goal:
- Pentair VSP
-- Speed 1 - 1900 rpm; Time - 8am; Duration - 24 [hrs].
-- Speeds 2 and 3 - left at previous schedule since assuming they are irrelevant if speed 1 has duration of 24 hour cycle. (e.g., Speeds 2 and 3 will auto adjust at 0 hour durations)
- The Hayward Aqua Plus
-- Timers menu: Filter T1 -all 8:00a-5:00p schedule.
-- Configuration Menu: filter pump is set at 1 speed (all variable speed settings are performed at the pump); Freeze control is enabled and set at 38 degrees (where it should run at 1900 rpm).
