- Jan 20, 2022
- 170
- Vinyl
- Hayward Aqua Rite (T-15)
Hello. In about 12 days, I’m planning on having some work done on my in-ground pool to repair cracks and the foundation underneath fiberglass steps. To do so, I need to drain the shallow end of the pool so it’s only 3-4 inches deep (it’s normally about 3-3.5 feet deep). The deep end is normally about 8 feet deep.
The pool is currently green and cloudy (see attached photo). This happens every year around this time unfortunately. I’m not sure if it’s the pollen, poor water management, or something else, but the only thing that has seemed to work in the past is dumping about 20 pounds of chlorine or turbo shock in the pool. However, I don’t want to do this before draining the pool, since I’d just waste all the newly added chemicals.
Once I drain the pool and refill with hose water, will the fresh water help with the algae problem? Or will I still need to do a pretty heavy round of shock? I just recently discovered the SLAM process here and am wondering if I should try that after the refill. Thanks for any help!
