Why is 7.5 the industry standard pH for pool water and not pH neutral 7?
Who says the TA is supposed to be 120? That is way too high and will just pull the pH up. Only reason to have it that high is if you are using acidic tablets which we don't recommend.
There really is not a set standard at 7.5. Chemistry dictates that the pH must be in the 7s to not damage the pool by either dissolving plaster or causing calcium scaling. But in addition is the human comfort factor.
