Paint manufactured on, or after, September 13, 1999 is basically worthless.
Architectural Coating Rule for Volatile Organic Compounds.
The Environmental Protection Agency published the architectural coatings rule on September 11, 1998 (63 FR 48848) under authority of Section 183(e) of the Clean Air Act.
This rule limits the amount of volatile organic compounds (VOC) that manufacturers and importers of architectural coatings can put into their products.
The rule also has container labeling requirements for architectural coatings.
There are different options for complying with the VOC limits, including exemptions for products that may be hard to reformulate.
APPLICABILITY.
Am I subject to the rule?
You are subject to this rule if you manufacture (includes certain packaging and repackaging) or import an architectural coating for sale or distribution in the United States.
Consumers and distributors who do not manufacture or import coatings are not subject to this rule.
What is an architectural coating?
An architectural coating (coating) is a coating recommended by the manufacturer for field application to the surface of a stationary structure, portable building, pavement, or curb to protect, decorate, or serve some other function.
Architectural coatings include many categories such as interior and exterior paints, traffic markings, sign paints, as well as industrial maintenance coatings.
Manufactured before September 13, 1999.
Coatings manufactured prior to September 13, 1999 can continue to be sold until the stocks are depleted.
Coating category.......................................................................................................................... Grams VOC per liter..... Pounds VOC per gallon.
