Pump motor just died for my Whisperflo pump. Second to die in past 11 years. Had a Marathon 1.5HP, that accommodated the internal reverse threaded screw on the shaft of the motor. When to my pool store and was told that Century Pro 1.65 HP/SF 1.0 would be a suitable replacement. When I went to install the new motor, the shaft has external threading to seat the impeller, but does not have an internal reverse threaded hole to accommodate the Impeller’s screw that is part of Whisperfloo design. I have read that these screws are not necessary to seat the impeller, as most current motors have the external threading on the shaft.
Two concerns: Will my original impeller accommodate the slight increase in HP, or do I need to accommodate by using an impeller rated for 2.0 HP?
second, but not being able to place the screw through the impeller and into the motor shaft, there is now a through-hole that is not sealed. Can’t imagine that is good. Are there other impellers that don’t have a through hole that I should use instead?
