Where to buy vinyl pool liner patch material?
May 28, 2017
25
MD
I have a few holes in my pool from my 12 year old repeatedly stabbing the liner with a pole. :confused: :mad: Last year we had a guy come out and professionally patch them with scuba gear and all that, and it was kind of expensive. Since then I have noticed two more holes and had the ones he fixed start coming loose again. I would like to try and DIY to save costs. I tried the cheap kits you can get at Walmart and it looks pretty horrible. Option two was Flex Tape, which seems to be holding temporarily. Option 3 is to try and find a real piece of vinyl with a similar pattern and use that, but the only ones I can find are on eBay for like $30+. Is there a better solution for buying them?
Reactions: Ldpmail
Can you post a photo of the pattern? Maybe a TFP user may have some extra laying around.
Yes! Here it is:
Probably pretty generic I assume.
Is there a local pool store where you can get a patch kit? Boxer adhesive holds pretty well.
Amazon.com : Pool Liner Repair 408517Boxer - 4 oz Vinyl Swimming Kit : Swimming Pool Maintenance Kits : Garden Outdoor
We have a leslie's but they said they only had the cheap patch kits like at Walmart. I did notice the guy that came to fix it the last time used Boxer's, so that's what I'll get.
