Every thermometer I buy is not acurate. Or doesn't sink. Or just a piece of junk. filix
I've had two of these (got another after smashing the first one flinging it end to end in the pool and missing slightly long) and have been very happy with it. Seems very accurate, or at least consistent. The wireless feature is very convenient. They're a little hard to find right now though.
Inkbird IBS-P01R Wireless Indoor & Outdoor Floating Pool Thermometer for Bath Water, Spas, Aquariums
Wireless Connection: The maximum connection distance is 300 feet. You can check temperature readings with the receiver without going outside the room.Accurate Reading: Support both Fahrenheit and Celsius readings.Premium quality: The thermometer has adopted high quality materials, it is solid...
inkbird.shop![]()
I have a thermometer built into a skimmer cover lid.
skimmer cover thermometer - Bing
Intelligent search from Bing makes it easier to quickly find what you’re looking for and rewards you.www.bing.com
I'm having the same problem. We've had the pool less than a year and been through four thermometers. It's ridiculous.
The idea of one built into the skimmer seems great, do you think the temperature reading is more accurate with the water shielded from the sun?
This is very interesting. I have a small well separate from the skimmer that houses my auto-filler and overflow. It has a lid and more importantly an equalizer tube that connects to the pool about 2' under the water. If I could mount the thing under the lid, out of the water, and run the sensor through the tube, that could be ideal...
On the other front, I figured out what was wrong with the typical thermometers you can buy everywhere:
The reading is accurate enough, but the thing floats on it's side and then ends up in the skimmer. Even after drilling more air holes in the top, for better venting, it would still lay on its side. So I took one apart and found a baffle about halfway up that was trapping air. Very stupid design. A few more drill holes a couple inches below the cap (just below the baffle) and now it rights itself no matter how I toss it back in.
I like gizmos, too, but now that I've solved for my "analog" thermometer's shortcomings, I may leave well enough alone...
Old thread, I know, don't be mad. This was my pool thermometer...it broke. I need something but I have an autocover so I need something that works with that. I was thinking a hangy thing from where the divider between shallow end and deep end might work. I need to go out and really look at the pool.I've had two of these (got another after smashing the first one flinging it end to end in the pool and missing slightly long) and have been very happy with it. Seems very accurate, or at least consistent. The wireless feature is very convenient. They're a little hard to find right now though.
inkbird.shop![]()
I use my Thermopop. Less expensive than the penHere's what I use... my digital meat thermometer. Not as convenient as other options but is highly accurate in just a couple seconds. ThermoWorks RT301WA Super-Fast® Pocket Thermometer
