Hey guys,
My head is spinning from reading all the posts about the Liquidator.
I ordered one today from Dave and was wondering, what type of tubing do I order from US Plastics to replace the tubbing that come with it? I know it is Tygon tubing but there are so many to chose from I dont know where to even start. I know the ID/OD of the tubbing but what type of tubing is what im after?
Also what thickness of walls of the tubing should be used?
I seen also where others were having problems with flow, my CYA level in my pool is around 70 so I am keeping the FC level at the target of 8, according to the chart we all use that Ben figured out, my question is, am I going to have a problem with the flow not being able to dispense enough Chlorine into the pool to keep up my FC levels? If so any suggestions as to how I can modify it to keep the levels up?( maybe drilling out the float switches and using as larger dia. tubing?) I am on the BBB method (using 6% Ultra bleach from Aldi) right now and switched over from tri-chlor about 2 weeks ago and couldnt be happier with the results. Man am I glad I switched over!!
Thanks in advance
Brian
Thanks in advance
Brian
