I removed my water line tiles because I knew there was a leak somewhere behind them.
So it turned out to be pretty bad around the skimmer.
I will knock out all the loose thinset and concrete, acid wash and pressure wash in the holes and all the way around where the tiles are going.
Looking in the Home Depot concrete isle, there is like 50 different kinds.
Any suggestions about what to use? Links to the HD products would be cool
Also, what should I use as thinset? It need quite a layer thickness some places, probably up to 3/4".
Thanks
Mike
Thanks
Mike
