- Oct 18, 2009
- 3,648
- Plaster
- Hayward Aqua Rite (T-15)
I was looking at my plaster's (Premix Marbletite) chemistry recommendations and here is what they recommend
POOL WATER CHEMISTRY
WARRANTY CLAIM PROCEDURES
It is necessary for the longevity of your pool finish and as a condition of this warranty, that the
following chemical guidelines and Sequestering Agent® levels must be followed and maintained:
Sanitizer levels must be maintained in accordance with the manufacture’s specifications of the
sanitizer you are using. (Example: Free Chlorine = 1 - 3ppm)
pH 7.2 - 7.6
Total Alkalinity (TA) 80 - 120 ppm
Calcium Hardness (CH) 200 - 400 ppm
Cyanuric Acid 40 - 60 ppm
Sequestering Agent 10 - 12 ppm (6oz. Per 10,000 gal of water)
Salt Water pools Lower pH to 7.2 weekly (Very Important)
Use Sequestering Agent for salt water pools
Pool fill water containing high levels of metals may need to be pre-treated and filtered before being added to your pool. Do Not stop the water while the pool is filling. If adding additional fill hoses, add to the deep end of the pool only. The initial process, including start up chemicals, should be done by a pool professional. This may take several days. Afterwards balance the pool water to the above noted water parameters. Check the pH several times per week for the first few weeks and add pool acid pre-diluted to the deep end of the pool to lower the pH to 7.0-7.2 range or lower if needed. Never allow the pH to rise above 7.6 during the first 30 days. Brush the pool daily for the first 30 days, then as needed. To help prevent metal stains and scaling of the finish and to up-hold your
product warranty, you must add the proper amount of Sequa-Sol® or any leading brand of
Sequestering Agent weekly. Noted above) After the first 30 days, check the pool water routinely at least once a week or more often and keep the water balanced to the above noted water chemistry parameters. For Salt water pools: do not add salt to the pool for the first 30 days. Be sure to add pool acid weekly and lower the pH to 7.2 ppm. No pool cleaners without brushes or vacuums with wheels for the first 30 days. Do not add Calcium for the first 60 days; then only if it is below 200 ppm.
I remember putting in some sequestering agent in the beginning however I have not added any more. I would like to know the pros and cons for using this chemical.
Thanks in advance
pH 7.2 - 7.6
Thanks in advance
