In Louisiana, we are expecting up to 6 inches of snow and temps as low as 13 degrees within the next 36-48 hours. I have a single pump with a spa and pool. I turned off freeze protect a long time ago b/c I didn't like the valve changing every 5 minutes as I've had issues with that one in the past; It has since been replaced. Anyway, I am currently warming up the pool to about 80 degrees. I plan to cut the heater before the snow starts and the temps drop to below freezing. I manually moved my intellivalve so I believe I'm pulling water through both sources (pool and spa). My pool setting pushes water through the spa jets. Few questions...
Am I doing enough for my equipment just leaving it running?
Do I still need to tarp the equipment? I have a tarp, but I'm concerned that the tarp will just collapse with the snow and create a mess.
Should I turn on my bubblers and deck jets to make sure water is flowing through those pipes too?
Weather: Snow starting early AM tonight. 36 hours ranging from 32 degrees down to 13. Wednesday the temps will get to the high 30's. Thursday afternoon I should be getting back up to the 40's and warmer weather arriving on Friday.
