Hi
There is a commercial pool with a water slide. The water slide gets turned on and off which diverts the water from the pool to the slide-the pump that turns on for the water slide is in the photo.
Currently, there seems to be too much water coming down the slide, meaning we lose lots of water over the sides each time a person slides down.
How would I reduce the water going down the slide-would it be by the two large valves or should it be by the control unit that turns the slide on or off- photo attached
thank
s for any help
thank
