Hi Everyone. I’m wondering if someone can help me turn on my water features for my pool. It looks like the 2 slits on my pool are water features? Thank you!!
Hey Jim…I am probably looking at this wrong, but did you mean to say rotate the valve on the “right” 180 degrees (whose handle in the picture is pointing “left”).
No, I meant the left... I only said that because a waterfall would normally operate on the return side.. I have never seen a water fall that had both suction side and return side plumbing..
Thanks said, I am just assuming... There is no obvious waterfall control at the pad...
Thanks for asking, as I often get things backwards..
Haha, I often do that…is it possible the pictures we see are reversed? I’m looking at the 2nd picture that has the pump/suction side on the left and the filter/return side on the right. I probably didn’t get enough sleep last night…
Ok, that is just weird... When you asked, I double checked to make sure I was right.. I then went to the OP's media to see what pics were posted and the picture was reversed, but there was only one pic.. When I went back to the thread... Like magic, the pump was on the left side..
@danicali 58 ... Turn the Return valve that sends water back to the pool 180 degrees... and see what happens.
