Hey folks,
I'm working on my plumbing to connect all my equipment for a new inground pool and spa. I need to install a water bonding fitting in the suction line to bond my water to everything else (perimeter, metal within 5 ft, etc). I understand this should be BEFORE any jandy valves and the pump so any water is always bonded. Since I have suction lines coming from two separate water sources (spa/pool) that are not normally connected, it seems I'm going to have to have two fittings and bondings. Is there a way this is normally handled instead of two separate pvc fittings with screw in bonding units?
