I've recently added an Ecostar 3400 VSP to my Hayward Goldline Aqualogic PS-4 control. I'm using the VSP timers to ramp the pump speed up and down according to what's on/off. I've figured out the following: Pump only (1250 RPM), pump & cleaner (1700 rpm), pump & solar (2100 RPM), pump & cleaner & solar (2450 rpm), pump & waterfall (w or w/o solar/cleaner) (3000 rpm). My board is below the 2.66 software version, so I want to control the VSP using the external relays but I don't have enough aux relays for everything. (Four relays on the PS-4, Pool, Light, Cleaner, spare). Only the cleaner uses one of the aux relays that I can tap into, so I want to use the Value 3 and Value 4 to trigger an external relay. The aux relay is triggered by the control w/24 VDC, so I can use a 24VDC relay for this function, but I can't figure out how to trigger a relay from the 24VAC that goes to the valve actuators. So my question is how have others overcome this problem? Has anyone figured out how to trigger a relay from the 24 VAC that goes to the valve actuators? I'm concerned about using a 24VAC relay and putting to much load on the valve actuator circuit. I can rectify the 24 VAC to DC but this gives me about 36 VDC. I don't believe that upgrading to a higher firmware (2.66?) on the aqualogic board would accomplish what I want because I don't think I can set the individual power levels based on what's running, but I may wrong. Right now, it all works fine with the individual run times programmed into the VSP to match the run times in the control, until I turn on the waterfall, then I have to manually ramp up the VSP. I'm open to suggestions.
