Hi all,
I have a Harward RS1000 pump and it currently has a SP US Motors K63CXEPZ-4767 1.5HP 1.3SF motor attached to it.
At the end of last year, the motor started grinding very loud and was leaking too.
I thought about trying to fix it myself but I also just like the idea of getting a new VS motor for it.
I've done some research and these are the things that I think are relevant.
The pool is 40x16 feet and with the sloping etc I estimate it has about 24k gallons.
2-inch pipes so max flow rate of 73GPM.
The filter is a Pentair S7M400 with a max flow rate of 115GPM.
No idea about the length of pipes etc so I don't know our total dynamic head.
I have worked out that it would need 49GPM to turn it over in 8 hours?
All that being true, it looks like I would be able to make do with a 1HP motor, but I'm intending to go to a 1.5HP motor.
When I search Google for a replacement for that pump I get directed to INYOPools.com and the AO Smith V-Green 1.65 HP Round Flange 56J Variable Speed Motor - ECM16CU.
Any thoughts on whether any of my assumptions or calculations are wrong?
Thoughts on that particular motor?
Suggestions for a different motor?
Am I best looking at replacing the full pump?
I've tried to do as much research myself as I can but dny guidance you can give me on this would be great.
Thanks as always.
Thanks as always.
