Variable Speed Pump Recommendation
taheso1033
9
Tennessee
I’m looking for advice on getting a new pool pump since my old one just stopped working. I’m aiming for something energy-efficient, and from what I’ve gathered, a variable speed pump running on a low setting might be the most economical choice. I’ve attached a photo of my current pump.
Here are my preferences:
• Voltage: 115/120v
• Horsepower: 1 HP (seems to use less electricity while providing similar power)
• Speed: Variable speed, to run on low RPM
• Features: A timer or scheduling function would be a big plus, but not required.
• Budget: Around $500, though I can be a bit flexible
If you have any recommendations or have had good experiences with specific models, I’d love to hear about them. Thanks in advance for your help!
• Voltage: 115/120v
A larger horsepower pump running at the lower speeds is how you save energy. Running a pump on 120v or 240V makes zero difference in how much it cost to move a certain amount of water. Work is measured in (and you pay for) watts and it takes the same amount whether 120V or 240V to d the job.
At that price point you are severely limiting yourself when trying to get a VSP that will run on 120V.
What pump do you have now? It may be a better option to get a variable-speed motor for it as some will run on both 120V or 240V. What brand, model, horsepower?
I think I’m wired for 120v. I’m currently using a Century Link 3/4 HP. It’s okay if it’s a little more than $500.
I’m currently looking at something like this, but it’s 240v.
Thanks for your help, I’m not knowledgeable when it comes to pumps.IMG_0029.jpeg
Thanks for your help, I’m not knowledgeable when it comes to pumps.View attachment 582724
NIdec Neptune NPTQ165 will work on that pump with that, or a larger (1.65THP), impeller. All control will be on the motor. It will work on 120V. Which pump do you have?
