Hey guys I am trying to get some help figuring out my problem.
I have a Zodiac MX8 cleaner and runs really slow, and will not climb walls. On the manual it says it should take 20-25 seconds for the wheel to rotate 10 times and it barely spins.
I don't believe the issue is with the MX8 as it is new, but something with my filter or pump.
Here is a pic of my diverter valve which i really dont know how to use. The only way the Mx8 slightly moves is in the current position, but there is 0 pressure on filter.
If I put valve on middle pressure starts going up to 10 PSI but MX8 barely moves, and if I put all the way to the left it does not move at all.
This is my pump
This is my filter
This is a pic further away of diverter valve
The basket is clean, and water only fills up when its in middle, or left position not right (where mx8 slightly moves)
I am trying to determine what can cause this, and or where should I start! Thank you very much!
I accidently put Mx6 on title! It id an MX8
This is my pump
This is my filter
