I know it's not a good idea to use petroleum jelly (Vaseline) to install O-Rings because it harms the rubber unless it's removed completely, immediately after installation, which is hard to do.
However, can undiluted dishwashing soap be used to install O-Rings? For example:
1. I need to slip a new O-Ring on the leaf canister that's upstream from the pool vacuum
2. So I apply a thin film of dishwashing soap on the new O-Ring
3. Hopefully the soap allows me to install the new O-Ring on the leaf canister easily
4. I then thoroughly wash off the dishwashing soap from the new O-Ring using a soft bristle toothbrush to remove soap left behind
I know silicon lubricants like "Magic LUBE" that costs around $9 but I have to remember where I kept it but if dishwashing soap works equally well and does no damage if cleaned within a few minutes, it's always by the sink and I need a tiny bit!
Have any of you personally used dishwashing soap instead of silicon lubricant?
Is there any hazard or danger to the new O-Ring if using dishwashing soap this specific way?
