Umbrella Sleeve Cap - Seized close due to plaster
JarCar
0
Mar 23, 2017
95
Katy, TX
So, we went to use the umbrella sleeve for the first time on our sunshelf and I could not remove the cap. Tried using some pliers, a box cutter around the lip to cut-away some plaster that may have hardened in the threads with zero luck.
Any suggestions for getting the cap off?
Thanks in advance.
@OP, will appreciate if you can update this thread post successful cap removal. Our pool was re-plastered last Dec and they also installed a cap on the umbrella sleeve on the sunshelf. Our 68F water temp is preventing me to take the dip, since. TIA
I'm going to give it a whirl tonight with the mallet idea. I'll let you know how it goes!
*Update*
I was able to get the cap off....this is what I had to do....
Used a screwdriver and hammer and essentially cut a square into the top of it. Then used a hacksaw blade and cut the cap into quarters and then just pried it out. Saved the threads on the sleeve so we are good to go.
Yeah I know, right....
Luckily I have two other sleeves for volleyball so I used one of those caps to make sure I didn't damage the threads and I didnt, so yay!
My biggest worry was for me to damage the overall sleeve and/or crack the plaster around it. Luckily that didn't happen.
We had the same problem but my husband tore up the cap and the threads are damaged. Is there a way to replace them?
Any ideas? I have uploaded a photo of the damages sleeve.
Thank you.
