Because one of the pipes on my sand filter multiport valve cracked over the winter, I need to replace the unit. I have the new Pentair unit but my problem is disconnecting the old PVC piping. The top pipe I freed but I have to rotate the pipe with the fitting since the fitting doesn't seem to rotate around the piping. The bottom pipe/fitting is not turning at all, in spite of efforts with a large channel lock wrench and silicon spray. Ideas?
Many thanks
Many thanks
