I have a 2010 Beacomber hot tub model 321, has worked perfectly. NOw the spa light is flashing on and off with a clicking noise and the buttons on the controller work randomly.
Before i replace the topside controller i would like to be sure that is the only issue.
I have unplugged the controller and restarted the spa and restarted the hot tub several times. It goes into Pr mode but takes a very long time to start up.
There seems to be no heat and it is stuck in Ec mode as it was before controller fritzed.
I have unplugged the spa light but the clicking noise continues.
The light button itself now changes the modes etc but it seems to stay in Ec mode.
I thought i read somewhere that if you disconnect the topside controller and restart it goes into some basic mode with heat and circulation is that the case?
Basically I would like to be sure the controller is the only issue.
Thanks
Thanks
